I’m getting ready to install a Helix DSP.2 which has an output voltage of 6 volts. My amps are a Helix A2 (max 8 volt input), Mosconi AS100.4 (max 5 volt input) and an Arc KS300.2 (max 4 volt input). In my head I should only slightly adjust the gain on the helix (8>6) and leave the arc and Mosconi at the lowest gain setting. Then I would need to go into the software and adjust the output gain on the channels that feed the arc and Mosconi until I reach the 4 and 5 volts respectively. From there I would continue to use the output gains in the software to level match.
Questions:
Is this the correct train of thought?
How do I test/know the given output voltage of a given channel from the helix?
Questions:
