1 - 6 of 6 Posts
29 amps isn't going to power much. You'll likely blow the fuse on the first heavy bass passage. It would be fine for HUs and small amps.
Right, I was thinking of picking up a few of them. Any suggestions?
Look at Iota, they make the ones that Stinger rebadges and charges $600 for. You can get used 75 amp Iotas for around $120 if you watch for them. They are also strapable. You can double them up for 150 amps. You can usually get the smaller amp models for under $100. They also can put out 14.2v on the high setting.
Thanks a-hole. Sorry had to say it :)
Any reason why the power supply I was looking at would not be "strappable"?
1 - 6 of 6 Posts
