Did you get it? I took a nap.
Did you get it? I took a nap.You are a bad influence! Lol
I'm sure you can hear changes real time. That's a good question though.I have a question first. I'm looking at the instructions and on an example computer screen, it has "write" on it. Well I'm well versed enough in electronics to know what that means. I'm guessing, you make your changes and then write to the amp for them to take effect? If I'm correct, and its not based on "realtime" adjustments.... I'm out. If its realtime, then I'm really considering it.
DSP4086: yes, you can hear changes in real time, as soon as you drag a point in the graphical representation, or as soon as you tab/enter/focus away from the parameter that you entered. "Write" makes it permanent, it takes a few seconds, and you can save it all to your laptop as well.I'm sure you can hear changes real time. That's a good question though.
I'm thinking about one these for a super cheap kia build.
That's what I figured. It's kinda they way they all work.DSP4086: yes, you can hear changes in real time, as soon as you drag a point in the graphical representation, or as soon as you tab/enter/focus away from the parameter that you entered. "Write" makes it permanent, it takes a few seconds, and you can save it all to your laptop as well.
So as you make changes, it changes that setting? Why do you have to “write” it? Does it lose those settings when powered off if you don’t write? Trying to get as much info on it before buying.DSP4086: yes, you can hear changes in real time, as soon as you drag a point in the graphical representation, or as soon as you tab/enter/focus away from the parameter that you entered. "Write" makes it permanent, it takes a few seconds, and you can save it all to your laptop as well.
It's the same sort of thing for the DSP-408 and minDSP 2x4s I use. You have to "save" (or "write") the changes (new settings) or those changes will be lost and the unit will revert to the previously saved (old) settings.So as you make changes, it changes that setting? Why do you have to “write” it? Does it lose those settings when powered off if you don’t write? Trying to get as much info on it before buying.
Yes just like any other program really.So as you make changes, it changes that setting? Why do you have to “write” it? Does it lose those settings when powered off if you don’t write? Trying to get as much info on it before buying.
https://www.crutchfield.com/p_109DSP4086/JBL-DSP4086.htmlwould look at that...So as you make changes, it changes that setting? Why do you have to “write” it? Does it lose those settings when powered off if you don’t write? Trying to get as much info on it before buying.
I saw that, went to JBL's website and saw it was the same price there too. So I started wondering if it was really on "sale" lolhttps://www.crutchfield.com/p_109DSP4086/JBL-DSP4086.htmlwould look at that...
On sale bro
I remember when a lot of people got these as refurbs from JBL.I saw that, went to JBL's website and saw it was the same price there too. So I started wondering if it was really on "sale" lol
I just bought this and am waiting for it to arrive. I am running a DSR1 right now and like it, however I need more outputs and want to use my subwoofer output on my radio. I hope I like this one.Won't this do what you need? https://www.minidsp.com/products/ca...pPT-ZoAPXs7o27WN62SHG0m_C6OqQpp0aAs9vEALw_wcB
Perfect timing. My check was $1400 short this monthim putting up two affordable DSP’s in the classifieds.
Wtf... explain.Perfect timing. My check was $1400 short this month![]()
Well for one we had a doozy of a month and for two I messed up when I changed my takes and they took out double what they normally do…..on a normal size check. I was only about $1400 short than my normal check. :eekWtf... explain.
You can't just drop that like this
