1 - 5 of 5 Posts
I'm thinking of throwing some 8" midbass/woofers into my rear 6x9 slots. Has anyone tried this before? I would probably have to bottom mount them somehow though. This would probably be enough low-end for me so I could ditch my sub box to make room in the trunk. I am wondering if the low-end would blend in okay with my fronts.
Any suggestion? Thanks!
DIYMA Founder
I've done it before. Works ok, but expect that the rear deck and any grilles covering those holes may rattle quite a bit. There also is some cancellation through the backseat on lower frequencies.
mitchyz250f said:
What is the best way (barrier) to stop the cancellation through the rear seats? I am curious (scared) because I am almost done mounting an Adire Tempest in the rear deck of my Passat.
bolt a big slab of wood to the rear of the back seats :)
I have as well. It's popular on my car audio forum; 3000gt's, because of the limited space.
The problem I had was the crossover point. I wanted to cross my mid-bass at around 260hz according to my drivers response (OZ Audio) but when I did my soundstage was pulled backwards - I used a 4th order. I ended up scraping the rear panel idea all together, as I found to keep the front stage where I wanted it, I had to cross the 8"s at 165hz, which limited my mid-bass usable bandwidth and caused lower limit pass-band distortion in my mid-range (4" OZ). So I guess it's up to your mid-range drivers, and what's noticeable to you in terms of soundstage according to the given x-over point/slope.
1 - 5 of 5 Posts
