matsurocka,
Nice trio of classics!
I've also used welding cable for years with no issues. I've also made heavy duty custom jumper cables for my small fleet of diesel grip & lighting trucks using welding cable. But if I need a really flexible/bendable cable, I pony up and go with Kicker's OFC Hyper-Flex power wire. It's pricey, but it's the best quality and most flexible car audio-branded power wire that I've ever used.
However, in the last several years I've started to outsource my custom power cable assemblies. I've found that I just can't beat the price once I factor in all of the individual parts costs to do it myself, not to mention the time involved:
power wire
ring or other terminals
hydraulic or HD mechanical crimper
adhesive-lined heatshrink
time
etc.
So, ultimately I've found that it's usually more cost- and time-effective to have
Gage Wire and Cable Co. on eBay make them. Again, I usually can't source all of the individual high-quality parts to make my own for what they charge, or it's at least a "break even" situation, and shipping is fast and very reasonable as well.
They make them in custom lengths and guages (call or email for custom lengths or terminals that aren't shown in the drop-down menus on their eBay page).
They use all American made high quality pure copper wire and ring terminals, using the best industrial quality crimping tools, and the terminal-to-wire junctions are sealed from air and moisture to prevent corrosion by using color-coded adhesive-lined heat shrink. Their quality and construction meet all regulations for automotive and marine use. Check them out on eBay at the following link:
Gauge Wire & Cable - eBay
About the only thing they don't do is Techflex, but in the engine compartment, I tend to go with good ole split-loom for a more OEM look. Now I just wish that I could have them come and do all of my wire and cable installation in my vehicles, LOL.
[Copy & Paste from another thread]...
Also, FYI, you should never solder crimped terminals. Especially on any wire larger than 12 AWG. OEM Automakers don't do it, the Aerospace and Marine industries don't do it, the Military doesn't do it, and neither should you.
There are multiple reasons that large gauge wire should not be soldered when using crimped terminals. I've posted all the specifics in several other threads on the subject if you want to search. Your cable connections may seem solid as a rock at the time you solder them, but don't be surprised if your homemade crimped and soldered cables fail at the wire/crimp terminal connection. At the very least, the quality of the connection will degrade over time.
If you're going to make your own power cables, spend $40 to $60 on a proper HD hydraulic crimper that includes multiple dies for different wire gauges, such as the TMS 16-Ton Hydraulic Crimper (find it on Amazon) or the 12-Ton version sold at Harbor Freight. Then used adhesive-lined heatshrink to seal the wire to terminal junctions.
Make sure that any cable or wire that you use is designated in size or guage (the actual conductor's cross sectional area) by "AWG" on the jacket or insulation. If not, the actual gauge or cross-sectional area of the actual wire is probably less than what it is marked.
Also, I really wouldn't bother with trying to save a few bucks by using CCA (Copper Clad Aluminum) wire. The tradeoffs aren't worth the difference in price IMO, especially when you can find Pure OFC welding cable at great prices.
