1 - 8 of 8 Posts
Vendor
hey guys,
anyone have a enclosure program that you can plug the following TS into and tell me just roughly what it says it can do for sealed?
its got a bit confusing info on it, it claims "small enclosure", yet says it wants 1.2 cubfeet almost for a 10", and it wants a bigger enclosure for sealed than ported...i am wondering if thats a misprint or just a largest one should go...
anyway, thanks in advance, gotta go fiberglass...
the t/s is attached below
Vendor
yeah, but its also a shallow sub (under 3.5"), so the 4.7mm xmax isnt that outrageous, the diamond sub for example, is at a mere 5.7" and a fs of 37...and that just calls for a .6 cubfeet?
Somewhere between 18 mm and 30 mm for sealed is decent ;)
Unless you can keep the volume knob turned to the left ;)
Stick it in a small box , with a natural reverberating frequency of 48 Hz the small box will give you a frequency range of 55 Hz and up ...
When I modeled my old DD 9510 it was the same way. The recommended sealed box was bigger than the ported.
What shallow sub is this?
1 - 8 of 8 Posts
