221 - 240 of 247 Posts
We ended up going a different direction,
I got it to work, and it would crash. I got the 1st measurements done and it crashed
I was trying to load crossovers and gave up. It just would boot me off
John had informed me that the presets are eq only so that along with the crashing
And the hourly rate we decided go with a minidsp , it does what the guy wants
By having presets that can turn off channels, and has Dirac live so it’s still a win win
And he has another device upstream also that has tons of fir ability so any residual group delay can be dealt with quite easily. I promised I wouldn’t spill the beans, but think million tap filters if one wanted. (Jel)
I am super impressed with the TDA software, that works so good. Way better than I thought it would I am definitely thinking about buying a copy for me.
I like tda very much. So much easier than reading impulses.
I wish I coulda heard it tho. Dang it. And this guy will have more fun with the mini being all his amps work off one dsp instead of having the apl and that another dsp for his rears.
And not having to worry about fir delay between the dsps . That makes tuning no fun, and if the apl has impulse offsets longer than 20.21ms the rears just wouldn’t have worked anyway.
On the 1012 tho the crossovers have a cutoff frequency for both the sides of the crossover that can’t be altered? Meaning, if you cross the sub at 100 the mid is 100 and no way to enter it diffrent forced complimentary crossover.
Makes me wonder if he does forward-backward filtering on that, it would give better stopband attinuation , the inband amplitude would carry the error which could be eq if I remember reading about backward running fir. Possibly saves taps too....so where he wanted overlapping speakers wouldn’t have had to do the peq option on crossovers. Not that that’s horrible, just one more thing that made this not the best option for this install , although would have still worked in a roundabout way. Just seemed like a lot of things to manage and work just to turn off a speaker pair or change a crossover slope or time align to another dsp.
But I digress,
Very curious about this dsp tho. Still has a lot of good things going on, for a traditional multi-way it could be one of the best. Definitely top 3 in my book
Another day I’ll get to work on one. Maybe I’ll buy one for a project.
I think the install drive was messed up I don’t know. But it all worked out well and worked out better for this particular setup
The defined/locked in crossover junctions is a good thing. The APL1012 corrects each drivers response to perfectly (or as close as can be achieved) align its acoustic response with that electrical filter so you have essentially beautifully aligned crossovers between drivers. There would be no reason to underlap or overlap if you have perfectly summed response. Just use the EQ for that ;)
I ran some REW sweep through mine to look at the phase response around the crossovers, it's REALLY cool to see perfectly flat phase through the crossover. If you use a LR crossover instead, you get the predictable phase shift. But if you then turn on Group Delay correction, the flat is perfectly flat again. I'll post up some screenshots tonight.
Yes I was surprised by that too. Also show the before and after FR correction of two drivers at the crossover point. It's quite good. :)
Reactions: oabeieo
Steve he had like duplicate channels , horns and tweeters for example ,
Definitely don’t want to cross horns at 3k
And that’s not all. There were a lot of speakers installed.
So that was my original point, like 2 seperate full systems of speakers in the front of this car plus all kinds of rears.
Although in fir crossovers, you don’t have to have the same frequency either, you can actually build filters that overlap and they sound amazing.
(Remember Steve, it’s linear phase so it don’t matter. The “crossover” is a amplitude only thing, all you do is make sure the driver is flat before applying the crossover and it playes perfect in time with the inband. The whole “crossover” mentality gets thrown out the window really. It opens a lot of doors
You should listen to a overlapping filter , bring the speakers down like 3 or 6 dB so your output isn’t doubled. Than for an oactave and let them interact and blend at -6db(I think that’s where pos puts them) , than shut them down fast like 48db is nice.
You can find them in rephase, there’s a whole bunch of unique filter designs , there one oactave overlapping, 1/2 oactave , 2 oactave , Ramionds told me you can use rephase (I never got that far)
He said the .fir ad .wav are the same and apl will read both
So if it’s 24bit you would export 24bitLpCM.wav in rephase
Throw it in a bank (oops I mean unit not bank) and enjoy.
But in that instance you get the blending than steep slopes.
So the outband interaction between speakers is almost non existent and the spekEkers are a oactave (or whatever) away so bye bye crossover interaction.
It’s like my most favorite filter for a tweeter or a horn to a mid.
I don’t care much for them in the LF I like plain old LR4 or LR8
Check it out tho ;)
Oooh yes yes. lol
I remember now. Man I used to watch wwf (e) like every episode
Back in the day , I can’t believe I forgot that.
That was before super h came on the scene if I remember right
That was the good ole days with Andre the giant and rick flare, and the hulk
Wasn’t Vince McMahon a wrestler (actor) also back than
I'll never look like that, I scared my hairline away a long time ago! :p
Here are a couple REW files to look at.
Index of /APL
The no loopback file is what I saw the other day when I was looking at things. I wanted to test delay through the unit as I fiddled with the crossovers, and it turned up some interesting phase stuff. Should I just ignore the phase in the loopback sweeps?
Tomorrow I'll toss the unit into by bedroom system and take some measurements of the actual audio using these crossovers. That system is a TV, a low end Yamaha receiver, some Acoustic Research bookshelf speakers, and a pair of W15GTI's running off a Crown XLS1002.
Well after my 1012 sitting in the closet for over a year, finally had the opportunity to get installed!
Being that I have a 7" CarPC, the windows 10 resolution was giving me fit getting the GUI to work without crashing everytime. Finally found a fix by using "overide high dpi" option in the C5 exe properties. Still slight scaling issue, but very useable and no crashes. Also, for anyone having program installation issues, ensure using "Administrator" privilege, also to install into the root level of your drive, C: or a flash drive. Might save you headaches. Also once you install the program, you must send Raimonds the siteID file so he can make and send your License file.
Anyway, the C5 GUI is not too complicated, once you get to tinkering around, theres really not much to figure out. Its layed out well in three simple tabs (there are a couple other tabs, but they are very limited to use). The downside, some of the buttons are not explained in the instructions, and for a basic amateur like me its a little intimidating on why/how/when to use. But thats what the DIYMA community is for, and of course Raimonds is very helpful.
I have not had any time yet to measure etc, but set basic crossovers and got music playing just to know I could. Will spend some time another day working on the tuning.
Question for those with experience, I am using:
Sub (1 way)
Midbass (2way)
Midrange (3way)
Tweeter (4way)
So in crossover I have:
Number of ways= 4
f1/2= 60 (sub/midbass)
f2/3= 300 (midbass/midrange)
f3/4= 3500 (midrange/tweeters)
f4/5= ???
Not sure what I put here as I don't want to cap my tweeters? Do I just put 20,000? But I think only lets me input up to 18,000?
Thanks!
Anyone with the 1012 using optical have any trouble when turning volume down to 0 (zero)? If I mute or turn to 0, the audio cuts off and nothing when I turn volume up. I have to physically unplug the optical cable and plug back in. Im assuming its some sort of signal sensing, and at 0 must turn off the optical...
my old Mosconi 6to8v8 I believe had a button checked that kept optical on no matter what.. never had this issue. I dont see a comparable solution in the settings anywhere.
I am using volume control from my steering wheel & carPC, not the volume knob included with 1012.
Thanks for any help in advance
Hi
Anyone faced clipping issues while working in C5.
It sometimes happens when I change delays or press the mute button while the music is playing. The associated speaker goes into nasty clipping/popping. The only way to stop is to turn off the car key.
It has happened twice in a couple of days with my midbass driver. It has happened before also with other drivers.
I am using digital input with approx 50% volume of my digital source.
Sent from my SM-G950F using Tapatalk
No, not any sound distortion for me. As you might see my previous post, I do lose sound after mute or turning vol to zero. I have to physically unplug the optical cable to get sound back.
Try unplugging your cable instead of turning car off, see if that fixes?
Earlier was using optical input now coaxial. I have seen this clipping with both.
The clipping is so bad that the driver would damage if don't shut off the system immediately. Removing the digital cable is going to take some time.
It's as if the driver has been given some 1000 watts.
Its something with c5. This only happens when I change settings while music is playing.
Otherwise the music plays clean and loud enough without any sort of distortion or clipping.
Attaching c5 main tab screen shot.
Will try reducing unit 2 channel gain in c5 and increase from the amp.
I have had the same thing happen. It seems to happen while trying to change settings rapidly. And that was with analog in and out. This is not an issue isolated to digital input/output usage. It's like while you are making tuning changes, it seems like the unit blasts to max output, without filters. Extremely dangerous for the drivers. All you can do is turn the volume down quickly and restart system to fix it. I would check with Raimonds to see what he says.
Yes..Exactly when changing things rapidly in c5. Like quickly muting one channel after another. Changing
before the previous task has fully processed by c5 and uploaded to the processor.
But with me this happens with digital inputs both optical and coaxial. I use analogue inputs only for taking measurements.
http://*****aplaudio*****/
Hello Friends!
Good health, good spring time, good tunes : )
Thank you Durgesh for question and issue reporting!
Each function (button press) needs time to execute.
It is very hard to implement the "ENABLE OFF" on every button on Graphic User Interface of the program.
So, if you working rapidly, you may start the new function (press button) before previous is completely executed.
One of them may be executed with error in such case and that actually happened in the Durgesh`s example.
If you need to change lot of settings, it is recommended to switch of "Direct Upload to the Unit".
Make your changes, switch the "Direct upload to the unit" on and press "Update All".
Please observe the speed of updating. It maximal available for your PC.
Please try to use your working speed less then previously observed when the "Direct upload to the unit" is on.
Good luck,
Raimonds
