I believe GD cor is automatic. It's calculated from the filters used and applied as cascaded phase correction on top of the other filters.Hi
Can anyone pls explain the use of Group Delay correction. What to look for and how to set the the time span in the crossover tab when GD cor is enabled. And and then how to verify that the entered time span is correct.
Or
Should I simply save IR (.wav) and import the .wav file as master in EQ3 and apply to all the units .
My crossovers are 80/ 350/4000.
I have spent almost 7-8 days but couldn't understand this part.
Sent from my SM-G950F using Tapatalk
