I have seen 2 different spec sheets on the ARC 2075SE.
Both rate it at 100wpc into 4 Ohms, and 175 into 2.
One states 350 Watts bridged into 1 Ohm (which, to me, implies about 350 Watts bridged into 4 or 2, as well, based on outputs listed above.)
The other states 350 Watts bridged into 4 Ohms, and 300 Bridged into 2.
I can't find a review where they tested the power or measured power vs THD.
I'm wondering how much juice I can expect, bridged into a 2 Ohm load.
Basically, on a pair of BM MKIV's, 4 Ohm VC's wired in parallel for a 2 Ohm load, but subs not wired together: is there an advantage to bridging a 2075SE into each woofer, vs running a single SE2150 (300wpc at 2 Ohms) in stereo on them?
Finally, is 300 watts enough for one of these for max SQ and plenty of headroom, or should I really try to get closer to, or exceed, the 450 Watts max?
Thank you for your help and insight.
