Moderator
Driver:
ARC Audio Black Series 4.0
Arc AudioBlack 4.0
Full report attached via PDF.
T/S and Impedance:
  • Re = 3.0532 ohms
  • Fs = 72.8961 Hz
  • Zmax = 34.5592 ohms
  • Qes = 0.6872
  • Qms = 7.0910
  • Qts = 0.6265
  • Le = 0.1776 mH (at 1 kHz)
  • Diam = 82.8040 mm ( 3.2600 in )
  • Sd = 5385.0845 mm^2( 8.3469 in^2)
  • Vas = 3.2630 L ( 0.1152 ft^3)
  • BL = 3.4632 N/A
  • Mms = 6.0054 g
  • Cms = 792.0765 uM/N
  • Kms = 1262.5043 N/M
  • Rms = 0.3812 R mechanical
  • Efficiency = 0.1728 %
  • Sensitivity= 84.3941 dB @1W/1m
  • Sensitivity= 88.5775 dB @2.83Vrms/1m
Klippel Distortion Parameters:
  • X Bl @ Bl min=82% 5.0 mm
  • X C @ C min=75% 3.5 mm
Sample Klippel Data:
Outstanding performance for a 4" midrange. The motor is somewhere between the Revelator and the Illuminator. The application is a bit tough to swallow, basically 1 cubic foot and loads of power but as long as you have that you can achieve a ridiculously low crossover point with this guy and get decent output. At SB acoustics prices this is a bargain top notch performance driver for those that have lots of room to play with. Should work really well in IB too.
These scream BMW to me. IE no midbass to share the door volume with, low crossover point to help the under seat midbass out, and good output to match. Oh and lets not forget the 4" IB center channel.
