1 - 14 of 14 Posts
Arc Ks300.4
$250 shipped
Insured
P-M is the key
Plz spare me with low-ball offers
Here is the skinny on this amp.
I was using it bridged to drive 2 hybrid L8 woofers, with the gain set at 30%.
It works flawlessly and never, ever got hot. I like lotsa head-room, w/o stressing the amplifier.
Description:
Fully adjustable high pass and low pass crossovers
Crossover range 55Hz-5.5KHz
18dB bass boost @45Hz
Low radiated noise for clean AM/FM reception
Stable to two ohms stereo
Very high damping factor
Optically isolated mosfet power supply
Can drive highly reactive loads
Protection against: reverse voltage, over voltage, speaker short, and thermal overload
Specifications:
Power output RMS @ 4 ohms: 4 x 90 watts
Power output RMS @ 2 ohms:4 x 175 watts
Power output RMS @ 4 ohms bridged: 2 x 350 watts
Transient Distortion (100 watts): <.02% @ 4 ohms
Frequency Response: 20Hz - 20 KHz
Signal to Noise Ratio: >95dB
Bass Boost: [email protected]
Crossover (Butterworth): 55Hz - 5.5 KHz variable 12dB
Fuse: 30A x 3
Discussion Starter #11 (Edited)
I snapped a few pics, but due to the way it is mounted...you cannot see the top of the casing.
More pics, once I have it removed, later today
1 - 14 of 14 Posts
