41 - 60 of 60 Posts
Discussion Starter #41
Updates available....simple fix
March 15, 2019
Download Desktop version 1.0.0.36
This link always redirects to the latest version.
Desktop:
PSC password fix.
Discussion Starter #42
New Firmware Posted
March 15, 2019
Desktop:
PSC password fix.
So, can this actually properly mix center and rear fill?
This is on the specs page, but I see zero mention of it anywhere else:
"Input Signal Mixer:
Yes - 10-Channels In (Including Digital) x 10-Channels Out (Including Up-Mixer Out)"
If it doesn't do center/fill up-mixing, what exactly is that specification referring to?
Yes it's upmixer is PL2
So it can do 10 channels out?? Or 8? I’m confused by this.
Discussion Starter #48
PS"8"
I see 8 physical outputs?
Where or how are you confused by this.
Sent from my LG-H873 using Tapatalk
Discussion Starter #49
With my truck
I plan to use channels 1 thru 6 in a typical 3way approach.
Channel 7 for center(upmixer/matrix routing)
Channel 8 for Sub
In the CES 2018 thread there was a post indicating Arc is not using a true upmixer. Where did you get the info that it has the Dolby algorithm?
(snip)
The Arc PS8 Pro has A LOT of really cool features. Fred was kind enough to demonstrate the software for several of us. It is going to be very powerful and excellent for everything from simple vehicle integration to very, very advanced tuning. I do fear that the interface and capabilities will be quite overwhelming for most novice timers. This is NOT a starter DSP (go talk to Geoff at PE), it is called PS8 Pro for a reason.
Now, the negatives on the PS8 Pro. Notice the name is still PS8? Yep, 8 channels of output. Not 12, not 10. I would have hoped to have seen more channels. Maybe CES 2019? Also, the DSP does not have a licensed upmixer. Same sort of signal summing features as Mosconi and Helix.
(snip)
Lies
It was my quote that was pulled from the CES 2018 thread. I relayed the information I was given at the time. It doesn't mean something hasn't changed since. Mic10is is the only person I have seen mention PL2. It would be great if we could get confirmation one way or the other from Arc.
Discussion Starter #54
New Update Available
Desktop:
Meter bug fixes.
PS8 Pro Firmware 10052:
Supports additional PSC Mute features.
I have both a PS8pro and 850 ...also on Team Arc. In my experience using the upmixer and what I've been told is that it's a version of pl2. My initial thought when I tried it that it was DTS, but was told a few times it's a version of PL2
I asked Arc Tech Support about the upmixer algorithm, here is their response:
"The PS8 Pro has some very simple center processing. It does not use the licensed processes like Logic7."
The alogorythm is going to be rewritten. It doesn't work that well for auto purposes
Discussion Starter #58
Version 10065 released.
New muting features added.
PSC bug fixes.
Works great
Discussion Starter #59
1.0.0.66 was just released this morning.
What's New:
Desktop:
  • Fixed missing serial number in support file
  • Added a support button on the Firmware tab
  • Recalling a file did not update the include checkboxes on the remote tab
  • Added DC protect logging
  • Additional support for ADS/Maestro
  • Additional support for Wi-Fi OTA firmware updates
PS8 Pro Firmware 10073:
  • Added backup storage for settings
Screen Shots:
Input Gain Wizard:
(BETA) Adv Parametric Tuning:
(BETA) Adv 1/3 Octave Tuning
Maestro Support:
41 - 60 of 60 Posts
