1 - 7 of 7 Posts
ARC Audio XXK 4050
General Features:
o Built-in Variable 12db per octave Crossover
o Crossover Range 55Hz-5.5Hz
o Stereo/Bridged/Mono Input mode selector switch
o Bass Boost 0-18dB @ 45Hz
o Short Circuit, Thermal, Reverse Voltage, over-voltage and DS offset Protection
o Very high damping factors
o Optically isolated Mosfet Power Supply
o Fully regulated power supplies produce full power output with battery voltage as low as 12 volts
o Symmetrical, discretre power amplifier circuitry
o Engineered to drive highly reactive loads.
o Built-in variable crossovers - 12db per octave crossover
o 12db/24db per octave woofer crossover
o Remote Bass Boost 0-18dB @ 45Hz
o Microprocessor controled power supply and Protection circuits
o Designed, Engineered and Assembled in the USA
Specification:
o Stereo @ 4 ohms: 4 x 50 watts
o Stereo @ 2 ohms: 4 x 90 watts
o Bridged @ 4 ohms:2 x 180 watts
o Bridged @ 2 ohms: Not Recommended
o THD %: <.07%
o Frequency Response: 20Hz - 20Khz
o Signalto Noise Ratio: 95dB
o Separation: >65db
o Transient Dist.: <.01
o Input sensitivity: 250 mv - 2.5v
o Bass Boost: +18 db @ 45Hz
o Crossover (Butterworth): 55Hz-5.5Khz 12db Stereo
o Max Current Draw: 46 amps
o Damping Factor: >300 @ 1Khz
o Dimensions: 13x8x3.35"
Excellent condition. Less than a year old.
$150 shipped
Bought this amp in May and used it with some Dyns with great results.
Reason for sale is I am getting into home audio and giving up some of my car audio gear to fund the home audio rig.
You will not find a better amp at or near this price.
Also the fully regulated power supply is nice as is the ability to run a 2 way active set up.
pm'd too
1 - 7 of 7 Posts
