I know there are many seasoned audio experts on this forum and I'm hoping to get some input here, no pun intended.
Basically, I have an audio control LC6i and a 300/4v2 and 5001/v2 JL Slash series amp. The issue(s) are that over the last 10 months I've had 3 AMPS GO BAD. There was an odd issue about 4 months ago where the volume would just randomly fluctuate on both my sub and 4 channel amps and anytime I had a screw driver near my gains or anything medal near the gains on my amps, there would be a power increase. It was an odd issue but had something to do with the boards in my amps. Both were replaced under warranty. But now I am having an impedance issue on my 300/4v2 amp, where the low impedance light stays on all the time even with all rca's and speaker wires disconnected from the amp. I had the amp tested today and it is definitely defective. All lines were tested with a voltmeter and are perfectly fine.
In talking with the guy that did the install initially, he thinks it may of been that my audio control "gains" were set too high. Audio Control actually states the way to set the gains is by disconnecting the rca's and turn the gains to the point where the maximize light gets solid..and then go back a notch. When I followed that, my gains on my LC6i got to about 80% of the way before the maximize light became solid so I set the gains at 75%.
The guy that did the install counters what audio control says in terms of setting the LC6i gains, because my Slash series amps draw a lot of power, much more then a typical amp and as a result, the gains on the LC6i should be set LOWER, and if more juice is needed, then the amp gains should be set higher.
So with this being said, i'm confused and have two questions. 1) Could the LC6i gains of been set too high, (even though I followed audio control's method of setting their LC6i) causing 3 JL amps to go bad in less then a year? 2) I guess this depends on the answer to question 1, but as of right now, my gains on my LC6i are all set to about a quarter of the way, while my amp gains are set to about half way. Am I losing anything but having the LC6i gains set as low as they are when they could be set all the way to 3/4 of the way before any clipping occurs?
Thanks VERY MUCH in advance for any advice or suggestions on this.
