Anyone know when BikeTronics will have the car-specific amps ready to ship?
I'm in the market for another 4250 and 6180, but I'm curious what configurations the car-specific amps will be available in?
Those Novello connectors are nice and streamlined.
I think I might still prefer the small 15/30/45 amp Anderson Power Pole connectors, mainly because both ends are protected by the housing. They also keep a solid and consistent contact due to the spring-loaded interlocking system. They are still relatively small and you can connect the housings together into as many pairs or group as you need.
Here's some more notes from a supplier:
https://powerwerx.com/anderson-powerpole-connectors-30amp-bonded
"The 15, 30 & 45 amp contacts all use the same housing. Therefore, they all connect to each other. The size of the flat contact area is actually the same for all contacts. The only difference between the 15, 30 & 45 amp contacts is the size of the receiving barrel that accepts the wire...
15 amp contacts are recommended for 20-16 gauge wire
30 amp contacts are recommended for 14-12 gauge wire
45 amp contacts are recommended for 10 gauge wire
- Powerpole connectors are both genderless and polarized connectors
- Powerpole connectors are genderless, meaning the supply and load connectors are the same. Since there are no male or female parts, all Powerpole connectors mate with themselves.
- Powerpole connectors become polarized when the red and black housings slide together via molded-in dovetails on the housings. Connections can be quickly made and remade sight-lessly or in the dark.
- Unassembled vs. Permanently Bonded:
Unassembled sets can be assembled in any configuration. As two housings slide together via molded-in dovetails, two half rounds align to form a channel that accepts a slotted roll pin. This prevents the housings from sliding apart. The roll pin is a compression fit and will not fall out in operation.
Powerwerx now offers Red/Black Powerpole sets that have been ultrasonically welded together which creates a permanent bond between the red and black housings. This can save assembly time, guarantee correct configuration, eliminate the need for a roll pin and enable the use of Powerpole accessories such as retaining clips or block-lok clamps." - Powerwerx
The Powerwerx Power Pole Crimper is The BOMB. Definitely worth the money if you think you'll be doing more than just a few of these types of connectors!
They also supply Round and Rectangular Panel Mounts...
