1 - 8 of 8 Posts
I believe you drive the same car I do, (5th gen, 94-97 accord.) Based upon your experience, will I be able to fit the Dayton RS180 7" in the doors without having to do a custom door panel?
I have no problem making spacers and sealing/deadening the doors, but I really don't want to have to "build-out" my factory panels.
If the 7" won't fit, will the RS150 6" still play low enough to have satisfactory front mid-bass?
Thanks,
-Ben
Sweet! So it looks like no problems to run the Dayton's.
As a side-bar question, the amp I've picked up to run my seperates is rated at 45x4 at 4 ohms. After reading some more, I'm afraid this won't be enough for the 7" Dayton's to provide satisfying mid-bass.
Any thoughts?
-Ben
Thanks for the reply. It looks like I'll be bridging the Xtant 4 channel down to 2, which should net 90x2 at 8ohm. Do you think this will be sufficient? As for the tweets, I'm looking at a 50x2 Xtant that would be running the RS Series tweets, which are 4ohm, correct?
Any more suggestions?
-Ben
1 - 8 of 8 Posts
