Moderator
For test setup, procedures, and information on how the data was obtained see sticky here:
http://www.diymobileaudio.com/forum/product-reviews-erin-harrdison-bikinpunk/103414-driver-testing-methods-setup-frequency-response-harmonic-distortion-only.html
Do not ask setup questions in this thread. This thread is only for driver discussion.
To understand how to read the data, try here:
http://www.diymobileaudio.com/forum/product-reviews-erin-harrdison-bikinpunk/103817-how-read-frequency-response-harmonic-distortion-plots.html
Driver Tested:
Audible Physics XR6.5M:
Impedance and T/S Parameters:
Frequency Response at 0 degrees, 3dB scale:
Frequency Response at 0, 15, 30, and 60 degrees, 5dB scale:
Harmonic Distortion at 95dB:
*** Special Note:
When testing this speaker I found that the distortion at 95dB was, indeed, legitimate. I tested at a few various levels and as you can see below, there is still an odd phenomena occurring at ~ 6-8khz. This seems to correlate with the primary frequency. The sound card gain inputs did not clip but came extremely close, which is what prompted me to test at a lower level (below).
I can, however, verify this occurred in multiple tests. What you see is exactly what I got with a voltage output required to drive the driver to 95dB, which was calculated from my measurement (and which almost exactly matches the mfg spec @ 1w/1m).
I'd hazard a guess that the 3rd order harmonic phenomena is tied directly to the frequency response in this region. As I sat in the room during one of the tests to make sure nothing was going on with the test setup to cause the occurrence, I found that the response in this region is very audibly high.
As backup, here's the limited bandwidth distortion at 90dB.
Limited Bandwidth Harmonic Distortion at 90dB:
