This came out of my old vehicle. I used it for about 3-4 months. It was a great amplifier with loads of power and has great build quality. Cosmetically it is 9/10, really nothing other than some mounting feet marks. If you are looking for a lot of power in a smaller size then this would be your amplifier. Shipping is on me within the USA via UPS.
  • Full Range Class D 4 Channel
  • Discrete Hi-Fidelity Design
  • Click-in-Place Crossover Controls
  • Band Pass Capable
  • Fan Cooled with 60 mm Fan
  • Tiffany Style RCA Connectors
  • Engineered in U.S.A and Korea
Continuous Power220W x 4 @ 4 ohms
14.4V Supply Voltage340W x 4 @ 2 ohms
Bridged680W x 2 @ 4 ohms
Frequency Response10Hz – 35KHz
Input Sensitivity0.2V to 6V
Recommended Fuse Ratings80A @ 4 ohms / 125A @ 2 ohms
Filter ModesHigh Pass – Low Pass – Band Pass
High Pass FilterCh 1+2: 20Hz – 5KHz
At 12dB/Oct SlopeCh 3+4: 50Hz – 5KHz
Linkwitz-Riley
Low Pass FilterCh 1+2: 20Hz – 5KHz
Linkwitz-Riley
Detented Filter Potentiometers41 Click-in-Place Frequencies
Remote Level Control w/ Clip IndicatorIncluded
Height2.64 in / 67 mm
Width7.54 in / 191.4 mm
Length11.82 in / 300.2 mm
Net Weight9 lb / 4.08 kg
