So I just installed this amp and I’m having an issue I never installed before, however this is my first Audison.
Anyway, I’m running this amp in my 2020 Dodge Charger with the PAC Amp Pro along with the Toslink Optical Adaptor. So obviously using the optical input on the Audison. So I hook up the computer and get everything all set up, all,the speakers, EQ, you know all the goodies. When I do this everything works and sounds good, although it needs tweaking, however this is where the issue comes in…. When I disconnect the USB from the computer, the music will play for about 10-15 seconds and then it stops. If I hook up the USB back up to the computer all the settings I did are gone. Even though I’ve saved them, they aren’t being saved for some reason. I tried everything. I’ve played with every setting I could find in the menus and nothing. Then I’m thinking a wiring issue, but everything seems to work just fine. Any one running this amp ever have this issue?
