Aura rpm2300. CV HED600.4. PSP-3000 playstation. Alpine SPS610 coaxial 6.5
1. Aura rpm stg2 2300
2. Cerwin Vega HED 600.4 SOLD FINALLY
3. Playstation PSP-3000
4. Alpine type S sps610 6.5 coaxial
1. Aura is new. never been out of box.
2.used for maybe 2 months .bought local new. swapped it for ppi phantom
3. new sealed. bought from Best buy. Piano black. just core system no games or acc.
4. used for 2 months with the HED amp
Total Price:
1. $90
2. $50
3. $120
4. $45
1. aura specs:
Specifications: *Power output (1% THD): 170 watts RMS x 2 (4 ohm), 270 watts RMS x 2 (2 ohm), 540 watts RMS x 1 (4 ohm) *S/N ratio: > 85 dB *THD: 0.1% @ 1 kHz *Switchable HP/LP crossover *Variable bass boost*Remote bass level *Damping factor: 200 *Dimensions: 9-1/8" W x 2-1/4" H x 15-5/8" L.
Highlights
Bridgeable and 2-ohm stereo stable
High-performance MOSFET power supply
Cool backlit top-illumination blue Aura logo
Remote bass level control
Selectable full-range, high pass, or low pass variable crossover
Gold plated RCA inputs, power inputs, and speaker outputs
Variable bass boost
2. HED 600.4 specs:
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 40 watts x 4 channels
RMS Power @ 2 ohms 75 watts x 4 channels
RMS Power @ 1 ohm Not Stable
Bridged RMS Power 150 watts x 2 channels
Peak Power Output 300 watts x 2 channels
Amplifier Specifications
Amplifier Class AB
Number of Channels 4
Total Peak Power Output 600 watts
Total RMS Power Output 300 watts
Maximum Input Gauge Size 8 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.03%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 50 - 250 Hz
Low-Pass Crossover Frequency 50 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 112 dB
Channel Separation N/A
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 25A x 2
CEA-2006 Compliant No
4. Alpine sps610
6-1/2" Type-S Series Car Speakers
Power Handling:
Peak: 480 watts per pair / 240 watts each
RMS: 160 watts per pair / 80 watts each (CEA-2031 Certified)
Tuned poly-mica cone woofer
Butyl rubber surround for natural response and stability
1" Wide-Range Silk dome tweeter
Optimized air-flow design
Progressive Aramid Fiber Spider with optimized shape for deep bass and linearity
HD Polymer frame
Affordable premium quality upgrade to your factory audio system
FEA optimized motor structure
OEM mounting adapters included
Great power-efficient speakers
Swivel-mount tweeter
4 ohms impedance
Square-wire short voice coil
New cone design allows for faster energy transfer & clarity
Aramid reinforced TIL bobbin holds voice coil wire very rigid
High grade network components
Neodymium tweeter magnet structure
Low distortion strontium woofer magnet
Speaker grilles KTE-S610G optional and sold separately
Top-mount depth: 2-1/4"
Total Price:
1. $90
2. $50
3. $120
4. $45
1. aura specs:
Highlights
Variable bass boost
2. HED 600.4 specs:
Amplifier Class AB
High-pass (HP)
Full (AP)
Subsonic Filter N/A
Fan Cooled Yes
Fuse Rating 25A x 2
4. Alpine sps610
Power Handling:
HD Polymer frame
4 ohms impedance
