Car: Holden VE Ute, what you may call a Pontiac G8 "truck".
Firstly, I'm Australian, its not a truck, its a ute.
Secondly, yes I'm a young bloke but I'm keen to learn and have a fair idea of what i want in my system, what i generally need is knowledge of which drivers out there can produce what i want.
What i currently have:
Front end - Kicker KS Splits in factory woofer and tweet positions, fed by a Kicker ZX350.4 4 channel, soon to be running active (read on)
Amp - 60w RMS per channel
4 AWG
Rear fill - Hertz ECX 690s in purpose built towers the behind seats, fed by Hertz HCP 4D 4 channel
Amp - 290w RMS Bridged
4AWG
Sub - Kicker CVT124 Slimline sub mounted in a custom built 0.7cu sealed enclosure between seats, fed by a Kicker CX1200.1 monoblock
Amp - 600w RMS mono @ 4ohm (one day the 4 ohm sub will get the ass)
4AWG
I'm running with the OEM headunit as it includes the AC controls and its a prick of a job to go aftermarket. And stupidly expensive if you speak to Alpine, eughh.
So currently running hi level straight into the CX1200.1 with no LOC and daisy chaining from the signal from there, I'm over it and want more versatility.
Hence,
Signal Processor - Rockford 3Sixty.3 (in transit, ordered last night)
The Grand Plan
1. Install 3Sixty.3 and see what exactly i can get out of what i have with some time correction, equalising everything and better crossover point/slopes, I'm looking at those Kicker splits, they'll be the first to go as I'm dying for a strong front stage.
Stage two will be dependant on two factors, how the kickers perform in the high-mids and how the Hertz perform in the midbass range as i would like to see them performing with some punch down to the 100hz range
If both fail, I'll need to prioritise
2. New front stage, ill be needing some big help here as I've been racking my brain for weeks looking for an affordable solution. I've been looking at Focal Flax, Focal K2, Morel, SStream but open to suggestions. I'm keen for a 3 way active front stage, i know it will make install bigger and very important, I'll be running them through 6 channels of the 3Sixty so should have the tuning ability, it will just force me to learn what im doing to make sure they perform right. I'm not sure if ill be wasting money on their accompanying passives though, should i be buying single drivers?
2. In the case the 6x9s don't cut it, I'm thinking a good pair of 10s, either side the 12" right behind the driver and passenger seats, should have some punch.. i'd think. I'm liking the reviews on MB Quart 10s but not sure if everyones referring to the the later models, particularly the RWM 10 inch. Also heard good words for Image Dynamics, but not sure about accessing them in the world up upside down. Also other options?
Lastly I'm no millionaire, I'm an apprentice instead, so no Utopia Be for me.
Probably got $1500 to play with realistically
Anyway if anyone out there in the land of knowledge and experience in car audio has any opinions please fire away
Ps: I know its a lot of drivers in a small space, i love bass kicks you can REALLY feel through your chest but want a clear front stage, certainly not after SPL figures
4 AWG
4AWG
4AWG
Hence,
The Grand Plan
