I have a very nice Autotek 5 channel amp for sale.
RMS Power @ 4 ohms: 4x55 + 1x220
RMS Power @ 2 ohms: 4x110 + 1x300
Evolution OF Power,upper tier, high-power car audio amplifier
Cool Pro-Fi MOSFETs
Bass Thrust EQ
Pro-Design Crossover
Pro-Design Hi-Pass
Pro-Design Low-Pass
Pro-Design Band-pass Feature (This allows you to use channels 1 and 2 as a midbass/midrange for a 2 way active setup for front stage)
Channel separation
The amp is absolutely gorgeous from an aesthetic/design perspective, has very simple yet very modern bold clean lines, has a solid, sleek, High Tech look to it. There are some amps that just look like cheaply made junk. This is definitely not one of them.
More importantly, it packs a punch, is very clean sounding, built like a tank so it has quite a bit of weight to it, does not have a large footprint and is very flexible with all it's built in features.
I would also guess it a bit underrated as it is very powerful. The sub section is very potent, has the ability to move a Mmats Pro Audio P3.0 in a sealed enclosure with serious authority. (which is what I was powering with it)
The amp is a 9 out of 10 appearance wise, there are very slight scuff marks on the surface that wouldn't ordinarily show up on an amp with a colored finish. This has a brushed aluminum heatsink which shows any little blemish. No deep scratches, dings or gouges, just light surface scuffs, anyone with stainless appliances would know what I am referring to..
Still, once the amp is mounted and you are standing at viewing distance, you will not see any imperfections, from 3 feet back, the amp looks perfect. It has been well cared for, functions 100%. BTW, I will switch the 30 amp fuse for the correct 60 amp.
Although it has been discontinued, it retailed for well over $500.00 when it was in production, it still retails for $379.00 plus shipping (I actually found a retailer online that is selling them for that price)
My asking price is $170.00 plus shipping.
I have no Rep as a seller here, but I have 100% postive feedback on Ebay with a feedback score of over 170, all car audio, mostly high end amps.
Ebay user ID is Eggstersampandstuff
I also have a positive rep as a seller on Car Audio.com under the same user name as here lust4sound. (may be upper case L, I can't remember at the moment)
Please check out my other ads for goodies on the cheap, I'm sure I have something for everyone.. Thanks for looking!!
Cool Pro-Fi MOSFETs
Bass Thrust EQ
Pro-Design Hi-Pass
Pro-Design Low-Pass
Channel separation
