Hi All!
I recently finished a nice high end build for my car, and as I've said it's pretty incredible and I'm very pleased.
NEW PROBLEM:
I needed to keep the factory head unit, which is feeding to a ARC Audio PS8 DSP. When I went to try a smartphone type source through the 3.5 aux on the head unit I was......displeased. It sounds bad.
I realized that the source itself - i.e. the phone is probably a big reason why. Now, my car does NOT have music bluetooth, only voice. and all the converters out there all still have the garbage source fed into a 3.5 aux port. I'm completely ok with plugging the source into a line, bluetooth isn't a necessity, it was just one more possible way to do something...
I'm looking for suggestions!
the PS8 does have a unbalanced 3.5 -- should I run a wire to the front of the car and use that? I also thought about a workaround using a portable DAC/AMP from the phone/source and then outputting that into the AUX port....
So - I could use some help here. NO - the head unit won't be replaced. The PS8 Bluetooth module is not out yet.....if ever.
SO...help!? Ideas?
NEW PROBLEM:
SO...help!? Ideas?
