I guess my first question should be, could the IDQ12D2V3 be suited for IB setup?
List of Specs:
IMP 1/4 ohms Nominal Impedance
Re .9 / 3.6 Ohms DC Resistance
Fs 26 Hz Resonant frequency
Qes .437 Electrical “Q”
Qms 2.806 Mechanical “Q”
Qts .374 Total “Q”
Vas 3.0 cuft (85 liters) Equivalent volume
Xmax 18 mm One way linear
Sd 519.45 cm2 Cone Area
Splo 87.22 dB Sensitivity
Pwr 50/500 Watts POWER Range
Or if I would prefer an IB setup, should I go to the 12" IDMax? Don't have the specs yet.
If the IDQ could be suited for IB setup, what will I need to modify in WinISD to get a good curve goin on. I will attached pics of what I have so far in the next hour.
I've also attached the spec sheet for the IDQ12D2V3 and will attach the IDMax when I receive it.
pic of winisd, second teal line is recommended port parameters, first yellow line is IB, 14 cu ft trunk
TIA!
List of Specs:
Qts .374 Total “Q”
TIA!
