1 - 12 of 12 Posts
I will only trade for a solid 2kw at 1ohm(or 4ohms).
Item(s) for Sale: 40x DataSafe 150RFR batts
Item(s) Description/Condition:
DataSafe NPX valve regulated lead-acid batteries are designed for high rate discharge applications. These batteries are used primarily where high wattage is required for a short duration. With 50% more wattage available and a 30% reduction in size over conventional batteries, DataSafe NPX batteries offer a superior value.
These DataSafe batts are made by Enersys, who also makes Stinger, Hawker, and Odyssey batteries...which we all know are pretty well respected. :D
- Sealed/maintenance-free - no water to add
- Sealed construction - can be operated in any position without leakage
- Rugged construction - high impact ABS plastic cases
- Rechargeable sealed lead acid battery
- Lead-calcium VRLA (AGM) technology
- 34.1lbs
- Dimensions: 7.76"L x 6.50"W x 6.89"H
- Resting at 12.9-13V
- Threaded inserts for easy connections
Price:
$105 shipped each
$100 shipped if buying more than one
$80 each for locals
Shipping and Miscellaneous Item Information:
Included in price, will be shipped via FedEx
Item Pictures:
When were these produced, and have they been previously used?
Thanks
Thanks
They were used in a Mitsubishi UPS cabinet and are 3 years old. With the resting voltage being so high at ~13V, you can tell that they were never really used much. They look great, and the threaded inserts are a nice touch.
1 - 12 of 12 Posts
