1 - 16 of 16 Posts
My 2015 mazda 3 has a five speaker front stage(bose) that consists of three 3.5" speakers in the dash(corners and center) and 9" woofers in the doors that I am looking to upgrade. I was planning on installing the 6.5s in the doors and bottom mounting the tweeters in the dash corners but I am concerned how they will sound firing into the glass in the stock locations. I want to keep it looking stock although I have considered surface mounting them in the corners and aiming them or maybe even the sail panels if it will sound better. Looking for sets around 100 rms.
I have been eyeing the Morel Tempo Ultra 602 on Crutchfield but I have noticed a few sets of Focal sets have gone on sale lately.
Will there be a noticeable difference in sound quality if I spend upwards of $500 instead of $300? I intend on using passive crossovers. The doors will also be deadened.
  1. Does it matter where I mount the crossover?
  2. Should I do anything to prevent moisture in the doors? My stock speakers had a little bit of rust on them.
  3. Any amp suggestions for 100 rms x 2 @ 4 ohms?
Get GS10’s and GS60’s, active no passive crossover, use DSP
But if you can’t afford DSP yet, grab the GS10C crossovers
Never compromise on woofer (midbass?) size.
They're factory "woofers" and I doubt a legitamite woofer that size will fit the door. They have inverted magnets.
That won't fit my budget.
Hi friend. Is your headunit sending a full range signal to the front stage? I assume the L,C,R are wideband speakers and they may be crossed too high for a mid.
That is the factory bose speaker system and I have no idea what the crossover setting are. For the install I will be using a Pac oem which will provide a full clean signal.
Have you read Andy’s “Basic 1 Seat Tuning Guide”? I wish I did before I went down the rabbit hole. Should help you understand the important design considerations and basics of speaker selection
??? GS10 is 229 GS60 is 279. That’s 508. Ur budget literally said 500 Plus lol
I haven't since I didn't intend to go active.
My budget is for passive components.
The section on component selection is basic audio theory, it will help you understand the trade off in driver sizes, beaming, reflection etc to make an informed choice yourself.
But to answer your question, there are many good options from focal, scanspeak, Dayton, SB acoustics- even for 300 - and bouncing tweeters off the windscreen definitely can work.
Discussion Starter #12
I didn't find any thread by that title.
I'm just saying, there are some nice component sets with large woofers that might work or be made to work.
Discussion Starter #15
Like what. I have been using Crutchfield primarily because it let's me know what will or will not fit my car.
I've got some nice Illusion Audio L6 components for sale within your budget. The mids have the magnet in front of the cone to keep the mounting depth low. Take a look here, if you're interested:
1 - 16 of 16 Posts
