1 - 5 of 5 Posts
Ok let me say first that a friend of mine who is going to be helping with the install managed a rim & car audio place for 2 years. Now I own an 08 Scion Tc. I have through gifts and my own purchase gotten the following which Im hoping to install the moment I get a day off. Here is what I have so far, Polk db 6501 component front speakers, Stock back speakers (for now), Soundstream Rubicon 5.800 5 channel amp, 2 10" Alpine Type R subs (don't know model or year as they are a bit older) in a sealed box. Now my question is my friend suggests that instead of using the amp to power the front and back speakers and the subs on the 5 channel amp, he suggests I can do the front & back speakers and the tweeters on the amp then later buy a mono amp for the subs. Any advice would be helpful. Also Im hooking this setup to a Pioneer Avic D3
I am sure others with more experience will chime in here, but I would use the amp to power the front components (bridge the front and rear channels) and the sub. Power the rear speakers off the Avic D3 for a little rear fill.
i am in a similar situation (5 channel amp and components up front) and I will be doing just that for now until I can get more/better amps and change up the front to an active 3-way setup.
We know what you have, but now it's, what are you after?
What is it that you want from your system? SPL, SQ, a bit of both? 25% of one and 75% of the other?
A one amp install?
The way I see it, you're perfectly fine using the 5.800. If you wish later on buy a 4 ch amp for the 4 corners and a sub amp if you find that the 5.800 isn't doing what you want, then sell the 5.800 to recoup some of the money spent on the other two amps.
Another question is where would I put the amp in the vehicle? The crossovers for the front components are hidden in my door panels. Also your suggesting I bridge the front and rear channels and put them on the components? or the sub? I don't want to buy a new amp anytime soon. The amp I got says @ 4 ohms it will bridge 70 x 4 & 200 x 1 or @ 2 ohms 115 x 4 & 340 x 1. Something near 25% spl and 75% SQ. I do listen to alot of rap and hip hop but Im in my rock kick atm (my music mood changes via the season summer = rap/hip hop winter = alt. rock & metal)
The specs I see online for it are
4 ohms: 70 watts x 4 chan. + 200 watts x 1 chan.
2 ohms: 115 watts x 4 chan. + 340 watts x 1 chan.
Bridged, 4 ohms: 230 watts x 2 chan.
I was saying to bridge the front/rear to give the 230 to each of the Polk Audio components and then you could have 340 to the subs if they are 4 ohm subs.
1 - 5 of 5 Posts
