U need it on mode setting for channels 1-4; where do u have the two rcas plugged in at coming from the ds18 bt receiver
Speaker 1 is wired to +CH1 and -CH2. The +CH1 connects to the + side on the speaker. The-CH2 connects to the - side of the same speaker.Wait a second u have your speaker wired wrong completely. U have them wired to positive on 1 and positive on 3 on the orange speaker wires and to the negative on 2 and negative on 4 on the black speaker wires…..the orange is one set of speaker wires and the all black is the other set of wires correct….if that is what u have done thst is your first big thing we have to fix…they also could be wired correct i just csnt tell if u the speaker wired have one black and orange wire and one balck wire from the pics
I have a sub. The one time I had audio from the 2 speakers, I had the sub connected with the switch set to 4 ohm, No audio came out of the sub. I have alternated trying to have it connected and disconnected to see if there was an issue the sub was causing.Are u running a sub? The reason i ask is u dont the sub output wired
Ok this is correct did u try what i told u with rca cablesSpeaker 1 is wired to +CH1 and -CH2. The +CH1 connects to the + side on the speaker. The-CH2 connects to the - side of the same speaker.
Speaker 2 is wired to +CH3 and -CH4
Positive wires have a red stripe, negative wires are all black
Its definately a problem with how u have it wired with the rcas….do u have an aftermarket deck by any chance? Also chang emthe xover switch to 3/4 to HPFI have a sub. The one time I had audio from the 2 speakers, I had the sub connected with the switch set to 4 ohm, No audio came out of the sub. I have alternated trying to have it connected and disconnected to see if there was an issue the sub was causing.
Same results.Do this for me remove all rcas except the rcas coming the bluetooth receiver into channels 1 & 2 and let me know whst happens…so remove all rcas from amp except the rca that come from the br receiver and plug them into 1 & 1 input
I do not have an aftermarket deckIts definately a problem with how u have it wired with the rcas….do u have an aftermarket deck by any chance
How good of a ground do u have right now and make sure to change 3/4 to HPFI do not have an aftermarket deck
I had searched across the web when this problem first happened. I came across a single post that said to use Y splitters to make it work.
Grounded directly to the battery - post.How good of a ground do u have right now and make sure to change 3/4 to HPF
How should I think about the 6 channels of RCA inputs? Which ones correspond to the bridged 1/2 channel and which ones correspond to the bridged 3/4 channel?Its definately a problem with how u have it wired with the rcas….do u have an aftermarket deck by any chance? Also chang emthe xover switch to 3/4 to HPF
I think i figured it outHow should I think about the 6 channels of RCA inputs? Which ones correspond to the bridged 1/2 channel and which ones correspond to the bridged 3/4 channel?
Do I want the 1st bluetooth output to connect all to 1 speaker's equivalent RCA inputs?
Do I want 1 of each of the bluetooth output to connect to the corresponding rca inputs?
Also, just, thank you for taking the time, I really really appreciate it.
