1 - 20 of 23 Posts
· Registered
Coming up very soon...I can't wait to install the new Mosconi D2 100.4 DSP.
The D2 will power up each corner, while the M-Line amplifier will be dedicated to run the mid bass drivers under the seats.
The car will be coded to HIFI too in order to flatten the radio EQ curve from factory.
The car has the basic sound system at the moment. No tweeters. No amplifier.
· Registered
Now these are the types of amps that I would actually display in a build of mine. Clean, classy, and to the point.
· Registered
Discussion Starter · #12 ·
Right fellas, update below, more to come
Work in progress...
OEM tweeter's covers
Working on the doors. Securing the crossover, installing the mid range speakers and sound deadening.
Trying out locations...
Tweeters going into place
· Registered
2015 BMW F34 335GT, 2014 Toyota FJ Cruiser, 2014 Subaru Outback
You need to cut both loops on the tweeter crossover (notch filter AND attenuation) and then boost the top octave in the DSP. Otherwise the tweeters sound harsh without the loops cut, and dull after. They don't seem to be optimized for on-axis mounting.
The midrange drivers are quite nice.
Good luck with your project! You may have some trouble getting wire into the well there.
· Registered
Discussion Starter · #15 ·
Intermediary update...
Doors back in place
All the trims removed from the trunk
Power
Rear trim removed
2 way coax speakers for the rear
Running dedicated wires for the underseats woofers
Upgrading the woofers
Jeez, thanks BMW. Woofers are now "glued" to the enclosure...
Tried everything could not remove them. Will look for new enclosures in the morning
More pictures tomorrow, amplifiers and support plate in place, did not take pictures yet.
· Registered
Discussion Starter · #17 ·
Dude, literally hundreds of pairs of those underseat woofers have been pried out. Stop trying and do it - don't make me be Yoda.
Thanks master Yoda for the advice
The customer wanted to keep the original speakers intact. But given the poor output they provide in the basic audio configuration...there was no much point. You can't hear bass at all anyway with or without them.
1 - 20 of 23 Posts
