1 - 11 of 11 Posts
Arc Audio XDI 1200.6 - 6- channel amp
Item is BNIB. Only removed for pictures
$575
On ME
I purchased two of these, but plans have since changed and I only need one. If you're on DIYMA, you already know exactly why these amps are so highly sought after. Specs are listed below.
4 Channels @ 4ohms (Ch 1-4) 150 Watts
4 Channels @ 2 ohms (Ch 1-4) 150 Watts
2 Channels @ 4 ohms (Ch 1-4 Bridged) 300 Watts
2 Channels @ 4 ohms (Ch 5-6) 150 Watts
2 Channels @ 2 ohms (Ch 5-6) 300 Watts
1 Channel @ 4 ohms (Ch 5-6 Bridged) 600 Watts
Frequency Response 20Hz - 20kHz
Crossover Range (Ch 1-2) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only)
Crossover Range (Ch 3-4) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only)
Crossover Range (Ch 5-6) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only)
BP capable Yes (Ch 1-2 & 5-6)
Bass Boost 0-12dB @ 45Hz (Channel 5-6 only)
Remote Level Control Included Yes - LP Ch. 5-6 Only
Input Sensitivity (Low) 200mV - 3.5V
Fuse 3 x 30 amp
Cosmetic Trim XDi Level 2
Dimensions 13.0"(L) x 6.268"(W) x 2.162"(H)
1 - 11 of 11 Posts
