I'm hoping for some advice on putting together a system for a 21' closed bow ski boat. I want to make it as efficient as possible to minimize battery drain. The system will be removed for the fall/winter, but will see a bit of moisture. It will be under the dash, where it can't get splashed, and aim to the rear of the open interior.
I would like to use ribbon tweeters, in a two way set up, but I'm a little conserned about dispersion. I want to be able to play loud and clean if possible. I have a PG zx450, and an Alpine 7833. I could maybe just run it off the deck. I would buy something else if needed.
I could add a sub later.
I have the following sitting around. Thinking of using the Focal 10v with a ribbon tweeter. But can mix and match anything. What I don't use will go into a car.
If I buy a ribbon tweeter, would like to keep the price at about $200/pr, but will spend more if it will make a big difference.
Here is what I have:
Hiquphon OW II
Focal 5V 4411
Focal 10v6411 I bought this from NABBOY at elitecaraudio who said it will be smooth from 30hz - 2.5 khz
CONE TYPE: Polyglass
2.83v/1m: 93.1db
WATTS: 100
Z: 6ohms
FS: 32.9hz
VAS: 116.9ltr
Qts: .38
Xmax: +/-3.5mm
I appreciate any assistance.
Tom
Hiquphon OW II
Focal 5V 4411
2.83v/1m: 93.1db
WATTS: 100
Z: 6ohms
FS: 32.9hz
VAS: 116.9ltr
Qts: .38
Xmax: +/-3.5mm
Tom
