1 - 20 of 44 Posts
Here's a few oldies - from high school, through 2009 - in no particular order.
Hope it helps some of you.
durango console for an 8w7. This was one of my first custom jobs. trying out some kerfing
my crosscut sled
cushioned up
Discussion Starter #2 (Edited)
this vette was either right before or after the durango. back in the old days
the top still fits
replaced the grills
door panels
riveted in place
had to tweak them to make the door close :/ but it all worked out.
Discussion Starter #4 (Edited)
a work truck
use felt instead of fleece - way better
i made a little stand for glassing little boxes
custom dash kit and trim
modified the stock sub box, which had a pair of DVC 6"ers, to fit an orion XTR10
My first attempt at a steel amp rack. Put an HD where the stock nav disc and changer went.
This isn't my style, but I did the best I could with what I had....
Yes, I flipped the emblem
rear cam
sirius under the hatch 'spoiler'
Sub trim
duramix holds the grill in place
Discussion Starter #7 (Edited)
Subaru
quick and dirty tweeter pods
LED's on plexi rings - never got 100% finished before the car sold.
6th order bandpass through rear deck
even quicker and dirtier rear deck trim for the ports and HD900/5. wrapped in gray microfiber, inserts never finished.
Discussion Starter #8 (Edited)
Older Silverado
Ran out of MDF on 12/31, stuck with using black walnut ply from a friend.
Trim work took a long time. This box sounds great, and looks real simple, but took a couple weeks to complete.
Grilles for amp rack and downfiring air flow
tricky gapping for vinyl
hosed on some ghetto bedliner. The box locks into place without fasteners.
Discussion Starter #9 (Edited)
done -
blacked out some plexi behind the grill - only wanted to show part of what ended up there.
I went back in and blacked out a few bits of MDF that were showing through
First glass box I ever made
That is real leather by the way - from the tempe fabric place. I posted a question before about how to get the wrinkles out - I had several ideas and several people say to redo it. I ended up deciding to leave it because it adds character... I know how to fix it, it wouldn't take that long, and I know now to stretch the crap out of it when you first put it in - also NEVER move from AZ to AK and expect leather not to wrinkle:D
what looks like a port in the top - you may notice - is nothing more than a vacuum pipe that Wayne Connolly said I could use. I had the idea for a wire channel and a plexi amp rack on top with blue led's in it at school there... I still have the plext I cut at school, but never got around to installing. whenever I have the time I'm always working on something besides my truck... I rigged up the little stand offs from some big washers and nuts laying around for the 'industrial' look... works for now.
This is as close to a volcano as I have ever been.
custom dash kit for a chrysler
molded in a pocket from another kit
You get the idea
this was fun
used construction paper for the pods. all i could get locally
Discussion Starter #12
this thing was ridiculous
molding a box to fit, just a little bit.
pair of 13w3's
'carbon fiber' vinyl
Discussion Starter #13
I did a cleansweep, JL stealthbox with 2 10w3's, gmax sub amp, g4500 speaker amp
took about 4 hours total
the floor in the center was not perfectly parallel to the edge, so the amps were slightly askew. fixed it in the rack with duraglass
Discussion Starter #14
having some fun in a really old nasty toyota.....
I bent some laminate (as in counter tops) around for the curvy front edge. he wanted wavy, so that's what he got.
slathered her up and blocked her down.
I used this as a sanding/blocking tutorial on fiberglassforums
Never got it wrapped. customer went to jail..... good thing I was paid in advance.
Discussion Starter #17
thanks
Here's another oldie. A pair of Eclipse 8000's in the rear deck of a saturn. Had to remove the 'helper rods' and install shocks. 2 shocks at different angles so the lid would open evenly.
all aluminum and stainless baby
Discussion Starter #18
I painted the whole car
How's that for a ghetto paint booth?
Discussion Starter #19
'78 Chevy - a Harley Davidson Tribute truck
A little time on the router and I had the same thing for the 6x9's in the rear
JL 10w0's, Eclipse XA5000, and Infinity speakers
Discussion Starter #20
makin' room
Most people would leave it this shape - but that's not my style. I hate 'volcano boxes' with a passion.
6oz of glass down
fixing the dips with foam.
this was all an experiment, and I learned a lot on this job.
rasp to knock it down.
plaster (drywall mud) for final shaping before more glass to lock it down.
speaker rings molded in.
1 - 20 of 44 Posts
