Hello guys I am having a difficult time trying to figure out what speakers to put on what amp and where I should wire my subs too. and how to wire the amps correctly here is what I all have sorry for how long it is but i know someone wants all the info. I don’t want to put any speakers on zone 1 of the head unit as I want all the speakers connected through amp or is there a way to have the amp hooked to that zone each piece I have had description from manufacture
1 1000 watt 4 channel amp (how do I hook the speakers together before the amp and RCAs
General Specifications
Channel 1/2 Crossovers
1 1500 watt mono amp
2 12 in skar DVC 4 OHM subs underneath back seat facing down
T/S Parameters
4 6.5in Skar front speakers 2 in the bow and 2 on each side of the driver
2 8in Skar speakers located in backseat facing out towards the bow
2 pair of Dual tower speakers 6.5in port and starboard sides total 4 speakers both pairs wired to one set of terminals obviously on my wakeboard tower
and my head unit has 4 separate zones it’s a Rockville RGHR45
Type | Multi-channel Marine Amplifier |
Class | A/B |
Bridgeable | Yes |
Strappable | No |
Fuse Rating | 120 Amp |
MOSFET Type | High Speed MOSFET Power Supply |
Damping Factor | 150< |
Amplifier Width | 6.20" |
Bass EQ (Boost) | Yes (0‚+6 dB‚+12 dB) |
Output Channels | 4 |
RCA Line Output | No |
Turn-On Circuit | Soft Turn-on Circuit |
Working Voltage | 8.5V - 16V |
Amplifier Height | 2.40" |
Amplifier Length | 18.75" |
Tri-Mode Capable | Yes |
Frequency Response | 20Hz - 20kHz |
Built-in Crossovers | HPF / Full-Range / LPF |
RMS Power at 2 Ohms | 250 Watts x 4 Channels (14.4v) |
RMS Power at 4 Ohms | 150 Watts x 4 Channels (14.4v) |
Efficiency at 4 Ohms | 0.65 |
Protection Built-in? | Yes - 4-Way (Thermal‚Voltage‚Speaker‚DC) |
Power & Ground Inputs | 4 Gauge |
Signal-to-Noise Ratio | 105 dB |
Low Level Input (Gain) | 6V - 0.2mV |
Low Pass Filter (Variable) | 50Hz - 500Hz |
High Pass Filter (Variable) | 20Hz - 5kHz |
Power & Protection Indicators | Yes - LED Indicators |
RMS Power at 4 Ohms (Bridged) | 500 Watts x 2 Channels (14.4v) |
Remote Bass Knob & Cable Included | No |
Low-Pass Filter | 50Hz - 500Hz |
High-Pass Filter | 20Hz - 5kHz |
Crossover Multiplier | N/A |
Crossover Type (Switchable) | High-Pass Filter / Full-Range / Low-Pass Filter |
Type | Monoblock Car Amplifier |
Class | D |
Bridgeable | No |
Strappable | No |
Fuse Rating | 150 Amp |
Output Channels | 1 |
Amplifier Height | 2.25" |
Amplifier Length | 14.37" |
Subsonic Control | Off - 50Hz |
Tri-Mode Capable | No |
Frequency Response | 20Hz - 250Hz |
RMS Power at 1 Ohm | 1500 Watts x 1 Channel (14.4v) |
Peak Power at 1 Ohm | 2300 Watts x 1 Channel (14.4v) |
RMS Power at 2 Ohms | 930 Watts x 1 Channel (14.4v) |
RMS Power at 4 Ohms | 550 Watts x 1 Channel (14.4v) |
Efficiency at 4 Ohms | 0.9 |
Signal-to-Noise Ratio | 85 dB |
Low Pass Filter (Variable) | 50Hz - 220Hz |
Remote Bass Knob & Cable Included | Yes |
Size | 12" |
Type | Car Subwoofer |
Cone Type | Competition Grade Pressed Paper Cone |
RMS Power | 500 Watts |
Peak Power | 800 Watts |
Surround Type | Stitched High Roll Foam Surround |
Voice Coil Size | 2.00" |
Magnet Slug Count | Single |
Voice Coil Layers | 4 |
Voice Coil Material | Copper (Pure Copper) |
Voice Coil Impedance | Dual 2 Ω |
Bl | 15.6 n/a |
Fs | 35.3 Hz |
Re | Dual 2 Ω |
Cms | 0.12 mm/N |
Qes | 0.62 |
Qms | 4.42 |
Qts | 0.55 |
Vas | 43.5 L |
Nref | 0.30% |
Xmax | 11 mm (one-way) |
Sensitvity | 86.7 dB |
Size | 6.5" |
Type | 2-Way Marine Grade Speaker |
RMS Power | 160 Watts (Pair) |
Peak Power | 320 Watts (Pair) |
Sensitivity | 88 dB |
Sold As Pair | Yes |
Tweeter Size | 1" |
Magnet Material | Ferrite |
Voice Coil Size | 1.25" |
Frequency Response | 57 Hz - 20,000 Hz |
Voice Coil Impedance | Single 4 Ω |
Size | 8" |
RMS Power | 250 Watts (Pair) |
Peak Power | 500 Watts (Pair) |
Sensitivity | 90.5 dB |
Tweeter Size | 1" |
Voice Coil Size | 1.5" |
Frequency Response | 49 Hz - 20,000 Hz |
- Pair Rockville RKL65MBW 6.5” 2-Way 700 Watt Marine Boat Speakers with LED Lights
- CEA Compliant Power Ratings
- Power Rating: 350 Watts Peak /85 Watts RMS Per Speaker
- Total Power: 700 Watts
- Beat sync LED’s flash to the rhythm of the music
- You can select either red or blue color LED’s on the wire harness
- No extra installation for the LED. It gets a power signal through your speaker wire
- The louder the music the more intense the LED’s flash
- Black and White detachable Grills
- Fully Marinized Against Salt & Fresh Water Conditions
- UV treated cone makes this completely Waterproof and rustproof
- Anti-corrosion Stainless Steel Terminals
- Molded ABS plastic for amazing sound and protection from the elements while out on the water
- Polypropylene Formed Cone
- 10 Oz Y30 top of the line magnet supports high power handling
- Rubber Surround
- High quality ferrite magnet
- 1” inch Polymer Tweeter
- Oversized 1” CCAW Kapton Voice Coil
- Pre-installed Stainless-Steel mounting screws included
- Perfect for Marine, Car, ATV and UTV applications
- Impedance: 4-Ohm
- Frequency Response: 35Hz - 20KHz
- Sound Pressure Level: 90dB @ 1w/1m
- Total Diameter: 7.3”
- Cutout Diameter: 5.6”
- Total Height: 3.86”
- Mounting Depth: 2.56
also have 2 tweeters CT haven’t placed them yet or if I should?
Quick Facts: | |
RMS Power: | 90 Watts (Pair) |
MAX Power: | 180 Watts (Pair) |
Speaker Type: | 4" Aluminum Super Tweeter |
Voice Coil Configuration: | Single 4-Ohm |
- Rockville RGHR45 Weather Resistant Gauge-Hole Digital Media Receiver with 4 Zones that each have independent volume control
- Includes wired remote with the ability to control the volume in each zone
- 3” TFT color display makes it easy to navigate
- Built in Bluetooth/USB/AM/FM playback
- Fits into a standard Gauge-Hole (Tachometer) Opening
- Built-in 72 x 4 Watt Peak high powered amplifier (28 x 4 RMS)
- 3 pairs of pre-amp outputs
- 4 zones each with volume control (zone 1 = built in amplifier, zone 2 and 3 are RCA outputs, and zone 4 is the sub output)
- Built in EQ with preset EQ curves (Pop, Classic, Rock, Jazz, Beat, Flat)
- IP66 Waterproof Certification (Tested to withstand the elements)
- USB Input to play back audio files store on a USB thumb drive or any other USB device
- USB plays video
- RCA A/V input to play back a video source
- Rear camera input
- RCA Aux Input
- AM/FM Radio Built In with 18 FM and 12 AM presets + US and European tuning
- Bluetooth built in to stream audio from any Bluetooth enabled device
- USB Input Charges Your Phone
- Big easy to use buttons
- Back-lit 3 inch TFT display
- IP66 waterproof level
- meet ASTM B117 and ASTM D4329 standards
- Humiseal coated PCB board for waterproofing and protection from the elements
- Required cutout: 2.99" (diameter) x 4.96" (depth) x 4.53” (top plate diameter)
- 6.24 inch depth included the top plate
- USB is 500mA and 5V and supports 16GB max
- Specs of the built in amplifier
- TDA7851L quadbridge power amplifier
- 4 x 72 watts peak @ 2 ohm
- 4 x 48 watts peak @ 4 ohms
- Highly efficient even when running at 2 ohms!
- Low distortion even at top volume
also I have a EQ I have no clue how to hook this up- General Specifications
THD 0.000005 Type Equalizer Output 6-Channel RCA Output (Front, Rear, and Subwoofer) DIN Size 1/2 DIN AUX Input RCA Auxiliary Input with Variable Gaine Adjustment w/ Aux Input Selectable Switch Main Input Balanced RCA Main Input EQ Dimensions 7.00" W x 4.50" D x 1.00" H Volume Controls Master & Subwoofer Operating Voltage 11v - 15v Built-In Line Driver Yes Signal-to-Noise Ratio 100 dB Max RCA Output Voltage 7 Volts Lowpass Frequency Switch 60Hz / 120 Hz Number of Frequency Bands 7 Adjustable Frequency Bands 50Hz, 125Hz, 320Hz, 750Hz, 2.2kHz, 6kHz, 16kHz Ground Loop Isolation Circuit Yes Installation Hardware Included Yes Frequency Bands Adjustment Range -12 dB to +12 dB
