1 - 5 of 5 Posts
I'll keep it short and sweet.
1 iDMax
1 Kicker ZX1000.1
Wired to - 2 ohm
Max Height - 13.5"
Max Width - 30.5"
Tuned to - 28hz or 30hz
Built With - 3/4" MDF and 4" Aeroports
Possible Box Sizes (net. volume) - 2.72 cu. ft. or 2.55 cu. ft.
Don't want port noise. How long are my ports and what is the depth of my box for I planning on using the width and height listed above. It's going in my LS.
Please
I think that a 4" aeroport may cause port noise. 2^2 * pi is about 12.5in^2 of port area, which may cause port noise. Doing 2 4" aeroports might be a good alternative and will get you 25in^2 of port area, which shouldn't have any port noise.
I personally would go with a slot port.
Get a modeling program already, model the sub and the enclosure, and look at the vent air velocity graph vs frequency and that can tell you whether or not you will have port noise.
1 - 5 of 5 Posts
