1 - 7 of 7 Posts
Just got off of the phone with PE. They gave me the following spec'ed requirements, although they sound a bit shy to me for a 12 sub, well at least the sealed requirements do...
Sealed: 0.25-0.5 cu feet
Ported: 1.2 cu feet ported to 25 hz (2"x10.5" port).
What do you guys think? I need a smaller box, so the HF is out of the question for me as the HO better fits my space requirments...thanks in advance.
yeah I plan on first doing the sealed box and really adding polyfill. The ported box is a secondary plan...only if I need more output/lower freq extension.
I seen that they got a good home design with the .65 box. That would actually be what I would try 1st since the extra bit of space will likely help your low end extention...
Is this going in a hatchback or SUV... cause the HF Free Air would be what I'd recommend in a trunk.
are the boxes really that small? jeeez what is it forn the 12HF or what about the 10's?
I can model it after my current box, 0.6 cu feet. If it doesnt work out well, then I can just add a few strips of MDF inside to cut down the internal volume. But the nice thing about sealed boxes is you can be 10% off on the size without negative issues...
2000 Chevy Silverado extended cab, under my rear seat...either up or down firing...
1 - 7 of 7 Posts
