1 - 7 of 7 Posts
· Registered
Here's my equipment to be installed
2 8w7
C3 components
C2 dash
Alpine CDE-hd149bt
HD900/5
I need a box volume of 1.87 cu. ft. I've attached some pictures of my box shape but I wanted to double check my calculations. The whole measure twice cut once. I'll be using 3/4 MDF I can change all dementions except the lenght which is 31" outside or 29.5 inside. I really need the help.
· Registered
It's hard to come up with something with only a single dimension. Here's an example though. If you're off by a few tenths of a cubic foot it's going to have no effect whatsoever.
· Registered
That's what I was looking for, how did you calculate it? I had to do it in 3 parts but it's gotta be easier than that. Only difference between mine and yours is my bottom was 12" and my front was 8" (do to sub depth being 7" and needing 1" for the pole vent.
· Premium Member
That must be a sealed box?
Is it a different routine porting a box like that? How would it be done?
1 - 7 of 7 Posts
