1 - 7 of 7 Posts
· Registered
Hope these help :)
Can upload more if required or e-mail them.
Got these about a week back. Quite well built though definitely not overbuilt like the Helix amplifiers.
The passive network does take up some real estate. the C 2M mid-range is not too big and should be fairly easy to install.
Same goes for the C6B mid-bass and the C1T tweeter.
· Registered
I have heard the 2-way kit :) based on which I decided to go for these. I will be using them passive for some time before I can add a DSP to the mix.
The mid-bass isn't the most aggressive of it's counterparts but it does have a very balanced sound to it.
The tweeter I liked a lot. The 2-way set was one of those setups that I could listen to hours without fatigue. Expecting these to similar but better of course.
· Registered
You are reaffirming my choice, lol. The Esprit isn't a really aggressive set also, but it seems to play very smooth and accurate. I've been tuning on it for quite a bit and think I about have it down. I actually I have an esprit 4" component set I've been thinking about making a 3 way out of, but I really think I am going to spring for the competition setup this spring.
· Registered
That's also a pretty good idea to go about with. Have the 4" set play from 200Hz or something in that region and have a good mid bass to cover the gap between sub bass and mid-range.
Or maybe use the 4" Espirit driver with the C62c 2-way set
· Registered
Discussion Starter · #7 ·
I just did this a week ago, I need some time to play with the tuning. Not sure if I like it or not.
1 - 7 of 7 Posts
