1 - 11 of 11 Posts
Moderator
These are getting tons of talk in the hot deals section and at $70-80 shipped for the component set, why not. These look like a pretty reasonable steal.
Can be found on Amazon here:
Amazon.com: Cadence Acoustics CWM-6KIT 6.5-Inch Aluminum Cone Component Speaker System: Electronics
Here is the thread on this site:
http://www.diymobileaudio.com/forum/member-reviews-product-comparisons/28905-$75-cadence-cwm-6kit-6-5-comps-new-value-leader.html
Here it is, guys. I'll edit this post with a picture of the driver later.
Note that I paused the test a couple times to change the protection parameters. This didn't skew the results in any way. I ran it full bore the second time just to make sure. had already made the PDF by then, though, so didn't want to re-make it (takes a bit of time to get it right).
Moderator
Discussion Starter · #2 ·
Displacement Limits
X Bl @ Bl min=82%= 3.5 mm
X C @ C min=75%= 2.8 mm
X L @ Z max=10 %= 1.9 mm
X d @ d2=10%= 14.5 mm
Certainly not a long throw driver at the distortion limits given above, but the sucker has a beautiful bell curve Bl and descending Le(x). Suspension is offset, but fairly symmetrical.
Displacement Limits
Do you like the descending LE(X)? To me this looks like a crap driver. Just about everything about it tests poor. At that price point it's probably what you'd expect. Not really a good deal imo.
Moderator
Symmetrically it's good. As far as excursion it's poor. The distortion due to surround is high, too.
Haven't looked in to it too much, TBH.
!!!!!Noob Alert!!!!
I own this component set. I am assuming that this would help the educated buyer with a purchasing decision based on what they're trying to accomplish. I also assume that this information could assist in the tuning process.
What does all of this mean in relation to how a speaker performs, what frequencies it handles well and which ones it doesn't?
AAAAAAAA what about these results make you come to that conclusion/
I'm sure this information somewhere on the internets. I'm going to start looking but I'd appreciate if you guys could put this in laymans terms.
****edit****
I probably should have added that I have very limited access to DIYMA while I'm at work. Now that I'm home I can read up...
I spoke to quick actually seems par for the course, shows up alright in modeling. It's actually performs really well and a tiny sealed enclosure.. it might be best in small kicks.
Knowing who is going to buy that set, they gonna end up IB in doors :rolleyes:
Kelvin
1 - 11 of 11 Posts
