1 - 20 of 30 Posts
Ok peeps I’m building a fibreglass enclosure for under the seats of my 2019 ram, anyone know off the top how much airspace it is if doing a “perfect” mold if the underside? I assume now so the question of the day is how exactly should I measure this? Fill it with something like sand? Some other fancy way?
Motor vehicle Hood Automotive lighting Vehicle Bumper
Once I create my enclosure/mold I coat the inside completely with resin. Once dried I fill with water and covert gallons to cf.
Just fill it with that bag of dog food you have there.
Sand, kitty liter, etc. will all work, use what you have. Unless it's a ported box I wouldn't stress too much about a perfectly accurate measurement.
You don’t worry about the water getting on the wood and causing damage at all?
its going to be ported yes and I’m just kinda curious as to what it is in there because I’ve been asked a few times now. Plus won’t I need to know airspace you figure out port size? I’ve never calculated to put a proper port in…. I’m still a noob….
If it's completely resin coated then water shouldn't be an issue. It's by far the easiest way to measure it. Unless you live in a desert I guess. Or a really cold climate, then you'd use snow.
Reactions: DoubleCrown
It looks like about 25 litres when I measure it by eye.
  • Haha
Reactions: LBaudio
use water, or packing peanuts or something similar.... Watter wont harm the ply wood in those few minutes in any way, especially if it is soaked with resin
Or rice or beans if you are one who likes to have a food horde.
Or dirt or fertiliser if you work the garden often.
I can just look at, and look a 25ltr Jerry can, and think… them two is about the same.
But a measurement is hard to beat,
Are you putting some raised stiffener fillets in it?
Or is it flexy at all?
Some dynamat and felt or similar could address any resonance concerns…
definitely he should put damping plates on the inside walls to prevent enclosure ringing... always a good thing with fiberglass enclosures
I use rice
Does any prefer Macaroni? Or bow tie pasta or Risoni?
I heard that ketchup is very accurate for measuring enclosure volume... anybody interested to try and report back??? 😇 🙃
Reactions: Holmz
Using Bolognase makes one look a bit “like someone not to be messed with”.
But using Macaroni, and then using a cheese sauce for the mask seal… just makes one look weird.
Maybe one could get away with it using a Regiano, but it would be quite a challenge. A Borrolo, in the hand, might help to pull it off… or some other Italian classic.
2015 Toyota Camry V6
I assume that was five years ago but you remember it like it was yesterday, as there are still little white beans everywhere.
Making a mess was a big concern as I considered using the bean bag chair.
I just moved slowly as I measured the volume, then vacuumed it all back out. It was amazingly uneventful. I even re-used the styrofoam beads to confirm the volume of the enclosure once it was complete.
And one last thing, this was only a few months back, no where near 5 years ago ;)
1 - 20 of 30 Posts
