1 - 8 of 8 Posts
I got a question for all mosconi 200.2 users, is it really stable at 2 ohm bridged? Really need to know from real users. 1000 watts would be perfect for my application but not sure if stable
I ran a 200.2 for quite awhile at 2 ohms bridged and never had a problem with it. Hardly even got warm and I would run it for hours at a time. Perfectly stable at 2 ohms
Just make sure you have some current available..
The 300.2 can put out 1546 Watt r.m.s. with a current draw of 198A
Yes that's what I was also worried about since its a class ab too much current draw
Also keep in mind that the amp CAN put out that amount of power... It will not do that on a constant basis.. As long as you're not listening at full tilt all the time then the real output will be a lot lower than 1kw... and so will be the current draw...
^^ I'm with this guy, just because it can, doesn't mean it should. if you need 1kw, get the 300.2 for headroom and wiggle room. Also, what subwoofer are you running??
1 - 8 of 8 Posts
