1 - 3 of 3 Posts
I have a 3 way Active setup thru a 3sixty.2 I want to remove it for tests but keep active setup. Can i use my 2ways passive xover to LP my woofer and use the HP on my tweeter with my amps HP?
Will I still be compromising the SQ of my woofer doing it this way?
thanks
rob
As long as the crossover points and slope jive with your setup, then yes, you can use passive crossovers on the woofer.
And yes, sound quality will take a hit. Also, you might have some issues with level matching.
I don't see any problem with doing it. I can't see SQ suffering enough to notice or even at all. Level matching won't be an issue either since you still have control of the amps gains.
1 - 3 of 3 Posts
