Can I use small wire gauge from stock HU to high-level inputs because of low current?
3638 Views 4 Replies 3 Participants Last post by  Holmz
Did some googling/DIYMA searches and couldn’t find much on this.
Knowing that an amp’s speaker wires require a thicker AWG because of the higher current, if you’re just sending that signal to the high-level inputs of an amplifier (or in my case a DSP) instead of the speakers, don’t these inputs have a high impedance, meaning low current, meaning you can use much thinner wire? Would I be fine using say, 18 or even 20 AWG wire for this?
I bet the answer is universal but if it helps, my stock HU outputs ~220W (no idea how that’s distributed amongst the speakers) and my DSP spec says its high-level inputs have an impedance of 180 ohms.
1 - 1 of 5 Posts
@Holmz math is completely accurate!
If you’re simply asking whether you can use the factory wire - yes.
Many, including myself, use the OEM wire with aftermarket speakers and aftermarket amps as with the power we’re discussing to mids /highs the benefits from moving to a larger wire is negligible. With that in mind using ORM wire to feed your DSP isn’t an issue.
Are you creating a build log?
-Eric
1 - 1 of 5 Posts
