1 - 3 of 3 Posts
I've got a bit.one without the DRC cable, and am having trouble sourcing one at short notice. I was wondering if someone could help me out with a small bit of investigating..
I can't find a picture of the DRC cable, but from the manual it looks like the DRC end only uses 5 of the 6 wires in the cable (One of the 6 is "keyed"?).
At the bit one end it is an RJ-12 (6P6C) connector. Again I have no picture.. I was wondering if you can see the wire colours at both end and if someone could let me know how they match up?
Discussion Starter #2
I might as well post these in case they are useful to anyone else:
The DRC end of the cable:
Still after the other end if anyone can oblige (and if it's possible to see the wire colours)..
Cheers
OK might have this sussed
"Flat modular cord with 6P6C RJ12 plug/socket
(standard USOC colour coding)
Line (+) Line (-)
Color Pin # Color Pin #
Pair 1 Green 4 Red 3
Pair 2 Black 2 Yellow 5
Pair 3 White 1 Blue 6"
Looks like a standard cable colour.
Will have a stab tonight. If it works I hope it helps someone else if they find this :)
7-pin 0.1" (2.54mm) IDC socket (a 6-pin will do it) and female pins are available here:
Pololu - 0.1" (2.54mm) Crimp Connector Housing: 1x7-Pin 10-Pack
1 - 3 of 3 Posts
