1 - 7 of 7 Posts
I removed the vapor barrier on my rear doors to install dynamat. Once I got all the dynamat on, I taped up the 1/8" CCF over the door.
First, is the 1/8" CCF enough or do I need to put a vapor barrier back in?
Second, is the foil tape going to be enough to hold up the CCF long term?
are you saying that you put the dynamat on the inside of the door, not the inside of the outter skin? just to clarify....
I put the dynamat on like normal, put the CCF over that, and put the panel back on.
Would I need to re-install a vapor barrier inbetween the CCF and the panel (I believe its called a 'door card'?) -- outside door skin-->dynamat-->inner door skin-->dynamat--> CCF--> \vapor barrier\ -->door panel
CCF will be impervious to moisture. Just test a sample to see if water passes through it or gets absorbed. If it doesn't, you're good. Why did you replace the stock vapor barrier with CCF? Rattles?
No rattles... Yet... I needed to take it off to get to the inside of the door. The plastic was glued down with a foam type of adhesive, much like spray foam but in a lot smaller quantity, but it made it unusable once I took it off.
Will the foil tape be enough to hold it up? The pins in the door card also seem to be sandwiching it on there too I suppose...
It's not likely to move once the trim panel is reinstalled. Whether the tape will maintain a seal around the edge will depend on he adhesive. Like to be OK id it's intended for HVAC duct work.
Where did you purchase the CCF from?
1 - 7 of 7 Posts
