1 - 3 of 3 Posts
So I just bought a used 9887 and it looks nice but I only get sound from tuner. Using external amps. cd timer goes and ipod too, everything displays but no sound. WTF?? I reset the unit by pressing the small pin sized button behind the face and still same.
Thanks in advance.
Thanks in advance.
Check that you are using the blue/white (remote turn-on) wire to trigger the amplifiers to turn on, not the solid blue wire (power antenna) ;).
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9887.PDF
The solid blue wire only carries +12V when the tuner is selected and will turn your amplifiers off when selecting other sources.
That was it, I never look at which one I use, I guess not all power antenna connections are powered the same way. Thanks.
1 - 3 of 3 Posts
