1 - 20 of 21 Posts
CDT Audio EF-80 8" SVC 4 OHM sub...pair, BNIB...$120 shipped
SEAS Prestige 27TAFNC/G (H1397) 1" Aluminum Dome Tweeter...pair, BNOB...$50 shipped
Used and new
Prices include shipping...I accept paypal only...Not accepting trades or [email protected] is my paypal address :
I am posting stock photos of the items. I loaned out my camera and will not have it back in a few days. All items represented in the stock photos show exactly what you will get. My negative feedback is from a dishonest seller. I will not post about it here, but you can do a search and read all the posts related to it.
Discussion Starter #2
Back up top...
The CDT subs I have for sale make great midbass'. They produce a warm, clean sound
Back up top...
will they work IB?
bump anyhow.
No, they won't work IB. They can work in really small enclosures though. The ideal range is .03 to .07 sealed
One more thing, I'll sell the CDT's for $100, but buyer has to split shipping cost with me
What are the specs on these? I can't find anything on EF series on CDT website.
Specifications
Diameter: 8” (200mm)
Sensitivity: 87.1 dB
Power Handling: 200 WRMS (400W Pk)
Frequency Response: 10 ~ 400 Hz
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 1.53” (39mm)
Peak Xmax: 10mm
Magnet Weight: 30 Oz
EF-80 8” Subwoofer
Technical Data
Free Air Resonance: 48 Hz
Voice Coil DC Resistance: 3.3 Ohms
Voice Coil Inductance @ 1 kHz: 1.4 mH
Mechanical Q (Qms): 7.2
Electrical Q (Qes): 0.47
Total Q (Qts): 0.44
Compliance Volume (Vas): 14 l; 0.49 ft3
Moving mass, Diaphragm: 50 Gr
Motor Force Factor: 10.4 Tm
Mounting depth
4.00” ( 100mm)
Outer diameter
8 1/4” (210mm)
Cutout diameter
7 1/4” (183mm)
Thiele-Small Parameters
How picky are they about getting 200 watts? Reason I ask is, I have limited amount of space to work with, trying to run a 5 channel amp. would like to run both of these, but am limited to 200 watts at 4 ohms and 2 ohm is not an option for my amp.
I'm sure you would be fine. I was originally going to run them as midbass in my kicks off of a JL 450/4 , but I decided I didn't want to cut that much into my kicks. I replaced these with a smaller midbass. These would rock as either mid-bass or as subs. However, these are not SPL type subs. These are SQ subs
SQ is what I'm looking for but I just realized they are single 4 ohm. No way to wire both of them to my amp and present a 4 ohm load. What do you think of running just 1 of them in as big a box as recommended?
Discussion Starter #13
The bigger the box you build the more power you will need to push to them. These are made to be placed in a .3 to .7 size box
whats the nominal impedance and the Fs on them?
Discussion Starter #17
Nominal Impedance 4 Ohms Voice Coil Resistance 2.7 Ohms
Recommended Frequency Range 2500 - 30000 Hz Voice Coil Inductance 0.03 mH
Short Term Power Handling * 220 W Force Factor 1.9 N/A
Long Term Power Handling * 90 W Free Air Resonance 1170 Hz
Characteristic Sensitivity (2.83V, 1m) 90 dB Moving Mass 0.30 g
Voice Coil Diameter 26 mm Effective Piston Area 7.5 cm2
Voice Coil Height 1.1 mm Magnetic Gap Flux Density 1.2 T
Air Gap Height 2 mm Magnet Weight 0.01 kg
Linear Coil Travel (p-p) 0.9 mm Total Weight 0.1 kg
http://www.madisound.com/store/manuals/seas/h1397.pdf
crap they wont work. i need 6 ohm nominal. thanks tho bro
1 - 20 of 21 Posts
