I have a 2000 BMW 323Ci Convertible. I am running a system with an MS-8 and would like to install a center channel but the 323Ci has HVAC vents right where the center channel should go. There are 2 center vents that are about 4" across. The best speaker that I've found so far is a Polk 5.25 SR because it sounds great, has a very small neo magnet structure, and is only 2.25" deep. My though is that I could trim or soften the vents to make room for the neo magnet then I would only need to have about 1.5 - 1.75" above the dash. With each vent being 4" across I would only need to remove about an inch from each vent (to fit the neo magnet) so the vents would still have about 3 inches across (3/4 of their original size) so they should still work pretty well.
Has anyone here tried to do anything like this? Looking for any help with how to move, cut, shift the vents to create the space I need but still allow for the HVAC to still work.
Any help here is greatly appreciated.
