Hey all..
I have an IDQ12v4 running off a mosconi AS200.2 so it's getting 700RMS @ 4ohms.
I had it in a 1.5cu box that was sealed in the back of my skyline and with the amp gain hardly adjusted off the minimal amount it was incredibly hard hitting and really acurate.
when i moved it into my VW jetta, i went from a 1.5cu box to a 1.8cu box running off the same amp, but I am running it off the factory head unit, which really shouldn't be an issue.....
I can not get the bass to hit anywhere near as hard without pretty much maxing out the gain on my amp - not something I want to do...
the rest of the system is a mosconi 6-8v8, HAT legatia L6SEcarbons and the Legatia ring radiator tweeters ( I'm in love with these tweeters btw) running active off an as200.4
looking for suggestions on what could be causing my issue? I would of thought going to a bigger box the sub should be hitting a fair bit harder. Should I try putting pollyfill inside the box? should I just go back to a 1.5cu box?
