1 - 6 of 6 Posts
Based on some info I found here I made some tweeter pods and I'm really proud of how they came out.
Drillin' them holes. I found with 3/8" it perfectly fit the nipple tightly and I was able to use the threads of the nipple to bite the pvc cap. I chose a pvc cap 1/4" larger than my tweeters so that I could wrap them with foam.
Next I did a couple of coats with the truck bed liner. Living in Maine makes it hard to paint things in the winter without killing yourself but probably applying around 55F. I did 2 coats.
I mocked them up to find the spots where I wanted to drill my pillar. Getting the painters tape to stick (or anything for that matter) to the pillar was tough.
I put foam around the outside edge of the tweeter so that it would fit tightly into the cap but still be adjustable. I can also adjust the angle of the pods themselves. And in the car with the diamond tweeters installed:
Of course I buttoned it all up afterward. This next week I am redoing my amp rack. Given my small amp shit the bed I now have to find room for two larger amps and having my amps on the backseat is lame as hell. I'm building a real amp rack that will go behind the back seat. There is about 18" between the seat back and my subwoofer box and I plan to make an amp rack 44"x16" which would allow me to install the amps sideways (to give even more room).
I took some pictures of the install but I'm sort of embarrassed about my amplifier rack. Once I finish my work next week I'll post the before and after pics along with the car I took all this gear out of.
Now I was looking at these and worried a little that the sun might hit the tweeters. These aluminum tweets are pretty tough but some silk ones might be damaged by the sun? I thought in the next revision I could make it hooded like a bullet camera...
Don't "hood" them. The waves leaving the driver need to immediately roll off radially. And that pizza box paint booth is awesome.
Thanks for the advice! After watching a lot of installs over the past few days on youtube I see nobody really worries about the sun even on their 2000$ components.
So does anybody looking at my pillar/dash have any advice where you might put a 3-way?? There is a 2.5" in the dash but reflections off the windshield can be a real downer (caused me trouble in a saab I had years ago).. I know the 2.5" drivers play well off axis... Can you get away with PVC pods for a 2.5"? I would have to do something different to make it look right...
Read Only
Tough call. My tweeter will sit above my 4" mid on the pillar. And what do you mean by "3-way?" A coaxial?
I mean 3 way components to add a midrange like a 2.5" for when I upgrade and go active. I've got plenty of time to mull it over, one thought I had would be building into the dash speaker grill which pops off.
Read Only
You're pretty ingenuitive, so I have the utmost faith in whatever you decide to do with the midrange :)
1 - 6 of 6 Posts
