1 - 7 of 7 Posts
Clarion Canada XC7420
9.0/10 bench tested
Total Price USD: :
$600(each) + shipping
$1200(both) + shipping
Buyer pays for shipping costs, along with insurance. Shipping must include insurance.
Shipped from Hamilton Ontario Canada. Duties may apply.
Clarion Canada | XC7420
Discussion Starter #2
Bump
Bump TTT
BUMP
BUMP!!!!!
Let me hopefully help out your thread.
First off, the title makes it kinda look like you will only ship to Canada. But clearly our friend will ship outside Canada. these are only available in Canada.
Second, I don't think many know what these amps are. they are powerfull amps with a full fledge DSP inside...PEQ per channel, full xovers(HP,LP,BP) + slopes, time alignment ,a bass knob that can be configured to do other things then base.
Finally they have 2 EXTRA channels of processing, so you essentially get a 6 channel DSP with one of these amps. So you can control a sub amp and apply processing to it or to a dedicated midbass amp for 3 way active.
You guys should really take a closer look, these amps are the real deal ;)
120 watts × 4 channel @ 4-Ohms
180 watts × 4 channel @ 2-Ohms
380 watts × 2 channel @ 4-Ohm
Signal to Noise Ratio: -89.0dB
DSP Controlled Amplifier
6 Channel Input, 2 Channel Output
Input Signal Matrix Mixer
Output Level Control with 6 group options -60 to +10dB in 0.1dB Steps
6 Channel 5-Band Parametric Equalizer with linking -24 to +15dB, 20Hz to 20kHz, Q: 0.1 to 15
Six Channel Time Alignment with 6 group options 0.01mSec steps, 5.08 mSec (174.6cm Max)
Stereo Crossovers (Highpass, Lowpass & Bandpass)
User Configurable Remote control -60dB to +5dB Max, 0.1 dB Steps
Equalizer and Crossover Response Plot display
Master Volume Control
Individual Channel Muting
User Configurable BC2 Included (-60 to +5dB, 0.1dB Step, Channel Selection)
Tri-On Remote turn-on circuit (Remote, Signal or BTL Detect)
Input, Post mixer, Post EQ and Output VU level meters
Speaker Level Input Adapters included
Dimensions: 9-7/32 x 6-7/8 x 2-3/16 inchs
Dimensions: 222 x 175 x 56 mm
Thanks AAAAAAA
1 - 7 of 7 Posts
